Giriş
The process to replace the battery involves a few steps. The first step is unscrewing the 15 screws that hold the bottom plate together to gain access to the battery. The second step is unplugging the battery carefully to be replaced.
Neye ihtiyacın var
Remove the eleven 5mm screws with a Phillips #0 bit.
Remove the four 2.5mm screws with a Phillips #0 bit.
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
The screws on corners doesnt have the same length. The Guide is wrong carefull!
