Ana içeriğe geç
MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement
Neye ihtiyacın var
  1. MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement, Hard disk drive: adım 1, 3 resimden 1. MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement, Hard disk drive: adım 1, 3 resimden 2. MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement, Hard disk drive: adım 1, 3 resimden 3.
    • Remove the eleven 5mm screws with a PH0 bit.
    • Remove the four 2.5mm screws with a PH0 bit.
    • Remove the bottom cover
  2. MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement: adım 2, 2 resimden 1. MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement: adım 2, 2 resimden 2.
    • Unplug the selected white wire located above the hard drive.
    • Unplug it gently by lifting it up to unlock the black cover that connects it to the motherboard. Do not break the black cover
  3. MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement: adım 3, 1 resimden 1.
    • Unplug the hard drive gently.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mafdy Wahib
369 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Nance Fall 2017 USF Tampa, Team S1-G4, Nance Fall 2017 üyesi
USFT-NANCE-F17S1G4
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 2,884
