Ana içeriğe geç
MSI GS60 6QE GHOST PRO 4K RAM Replacement
Neye ihtiyacın var
  1. MSI GS60 6QE GHOST PRO 4K RAM Replacement, Battery: adım 1, 2 resimden 1. MSI GS60 6QE GHOST PRO 4K RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the eleven 5mm screws with a Phillips #0 bit.
    • Remove the four 2.5mm screws with a Phillips #0 bit.
  2. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 2, 2 resimden 1. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 2, 2 resimden 2.
    • After opening the bottom plate, locate the battery and the battery connection.
  3. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 3, 2 resimden 1. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 3, 2 resimden 2.
    • Unplug the battery connection carefully from the motherboard, and remove the old battery.
  4. MSI GS60 6QE GHOST PRO 4K RAM Replacement, Motherboard: adım 4, 1 resimden 1.
    • Remove the four 2.5 mm screws from the motherboard.
  5. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 5, 1 resimden 1.
    • Unplug the speaker wire.
  6. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 6, 2 resimden 1. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 6, 2 resimden 2.
    • Gently lift the selected black tab that connects the cable onto the board and then slide out the cable.
    • Be careful not to break the black cover.
  7. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 7, 2 resimden 1. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 7, 2 resimden 2.
    • Be careful not to break the black cover because it can be broken easily
  8. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 8, 1 resimden 1.
    • Be careful not to break the black cover. lift it up gently
  9. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 9, 2 resimden 1. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 9, 2 resimden 2.
  10. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 10, 2 resimden 1. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 10, 2 resimden 2.
  11. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 11, 2 resimden 1. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 11, 2 resimden 2.
    • Unplug the selected cable
  12. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 12, 3 resimden 1. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 12, 3 resimden 2. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 12, 3 resimden 3.
    • Locate and unplug the selected cables.
  13. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 13, 2 resimden 1. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 13, 2 resimden 2.
    • Unplug it carefully without breaking the black cover.
  14. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 14, 2 resimden 1. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 14, 2 resimden 2.
    • Gently unplug the selected cable
  15. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 15, 2 resimden 1. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 15, 2 resimden 2.
    • Gently remove the electronic component by sliding it out and lifting it up after unscrewing the 2.5 mm screw
    • Make sure your unscrew the screw first and unplug the chip from the motherboard. Do not disconnect the wires connected to the chip
  16. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 16, 1 resimden 1.
    • After unplugging all of the cables and unscrewing all of the screws, gently remove the motherboard out of the computer chassis
    • This part will take some effort but remember not to apply to much pressure on the motherboard as to not damage any of the small electrical components on the board
  17. MSI GS60 6QE GHOST PRO 4K RAM Replacement, RAM: adım 17, 1 resimden 1.
    • After removing the motherboard from the laptop chassis locate the RAM chips indicated by the red rectangle.
  18. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 18, 2 resimden 1. MSI GS60 6QE GHOST PRO 4K RAM Replacement: adım 18, 2 resimden 2.
    • Firmly grip the two rectangular Ram components, one at a time, and pull them up from the Motherboard, be gentle. Once this process is complete, you have successfully removed the Ram.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Justin Pelley
161 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Nance Fall 2017 USF Tampa, Team S1-G4, Nance Fall 2017 üyesi
USFT-NANCE-F17S1G4
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Thank you very much for this guide. I’ve successfully managed to replace my RAM with 16GB module.
Ondřej Kyzek - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 2,959
