Giriş
Replacing RAM or NVMe in the Stealth Pro. In order to replace the RAM or NVMe in the Stealth Pro, you'll have to remove some other parts that get in the way.
Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$4.99
Unscrew the 15 screws on the bottom panel using a Phillips #00 screwdriver.
Pry open the back cover with a plastic prying tool.
Use a Phillips screwdriver to remove the 15 screws securing the back cover.
Insert an opening tool or spudger in the seam and pry along the perimeter to loosen the back cover.
Remove the back cover.
Once the battery is out, remove the screws at each standoff with a #00 Phillips screwdriver.
Remove the two additional screws under the fans.
Remove the screw securing the Wi-Fi card.
Disconnect and remove the wifi card from the motherboard.
Disconnect the additional cables connected to the motherboard.
Carefully lift the motherboard out of the computer.
The screen cable in the top left is short and restricts movement when removing the motherboard.
8 farklı kişi bu kılavuzu tamamladı.
