Giriş
If you're having connectivity issues with your Stealth Pro, or simply want to upgrade your connectivity, this guide will walk you through the replacement process.
Neye ihtiyacın var
Unscrew the 15 screws on the bottom panel of the computer using a Phillips #00 screwdriver.
Lift open the back cover with a plastic spudger.
Gently lift the back cover away from computer. Make sure nothing is attached.
Unplug the battery cable from the motherboard to prevent a ground fault.
Unscrew the single screw from the Wifi card using a Phillips #00 screwdriver.
Apply upward pressure on the cables using a plastic tweezer.
Using the plastic tweezers, carefully grab and gently wiggle the Wifi card out of its socket.
Gently pull the card upward from the slot.
Bir başkası bu kılavuzu tamamladı.
3 Yorum
Is this a msata card or a m.2 card?
Hi, do you know where I can find some new wifi cables? I broke mine (with my WiFi card) and looking to repair it
Best regards
