Ana içeriğe geç
MSI GS66 Stealth 11UE-007 Cooling Fan Replacement
Neye ihtiyacın var
  1. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: adım 1, 1 resimden 1.
    • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
    • Make sure to unplug device for any outlet.
  2. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 2, 3 resimden 1. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 2, 3 resimden 2. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 2, 3 resimden 3.
    • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
    • Remove eight 10mm Phillips J1 screws.
    • Remove one 7mm Philips J1 screw from the center bottom of backplate.
  3. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 3, 3 resimden 1. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 3, 3 resimden 2. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 3, 3 resimden 3.
    • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
    • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
  4. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 4, 2 resimden 1. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Disconnect the wires from the cooling fan.
  5. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 5, 2 resimden 1. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 5, 2 resimden 2.
    • Disconnect the two wires from the Wi-Fi card.
  6. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 6, 3 resimden 1. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 6, 3 resimden 2. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 6, 3 resimden 3.
    • Remove the nine 6 mm screws.
  7. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 7, 2 resimden 1. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 7, 2 resimden 2.
    • Remove the tape connecting the fans to the fan housing.
  8. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: adım 8, 1 resimden 1.
    • Lift up the cooling unit like it is hinged at the back.
    • Replace thermal paste.
  9. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, Cooling Fan: adım 9, 3 resimden 1. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, Cooling Fan: adım 9, 3 resimden 2. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, Cooling Fan: adım 9, 3 resimden 3.
    • Remove the fans
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alex Robinson
1.057 İtibar
6 adet Kılavuz yazıldı
Bir Yorum
Has anyone found a solution to this issue yet, that doesn't require micro soldering`````````````Jorge Rodriguez.
Rachel Kelley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 23
Son 30 gün: 106
Her zaman: 717
