Ana içeriğe geç
MSI GS66 Stealth 11UE-007 NVMe SSD Replacement
Neye ihtiyacın var
  1. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement, NVMe SSD: adım 1, 1 resimden 1.
    • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
    • Make sure device is not connected to any outlet.
  2. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: adım 2, 1 resimden 1.
    • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
  3. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: adım 3, 1 resimden 1.
    • Remove eight 10 mm Phillips #1 screws.
  4. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: adım 4, 1 resimden 1.
    • Remove one 7 mm Philips #1 screw from the center bottom of backplate.
  5. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: adım 5, 3 resimden 1. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: adım 5, 3 resimden 2. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: adım 5, 3 resimden 3.
    • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
    • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate it from the body of the laptop.
  6. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: adım 6, 1 resimden 1.
    • Lift back black plastic.
  7. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: adım 7, 1 resimden 1.
    • Remove one 4 mm Phillips #1 screw.
  8. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: adım 8, 2 resimden 1. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: adım 8, 2 resimden 2.
    • Lift the drive up to forty-five degrees and pull at that forty-five degree angle away from the connector.
  9. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: adım 9, 2 resimden 1. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: adım 9, 2 resimden 2.
    • Remove the thermal pad.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Robinson
1.057 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 187
