Ana içeriğe geç
MSI GS66 Stealth 11UE-007 RAM Replacement
Neye ihtiyacın var
    1. MSI GS66 Stealth 11UE-007 RAM Replacement, RAM: adım 1, 1 resimden 1.
      • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
      • Make sure to unplug device from any outlet.
      FixBot'a Sor
      Yorum Ekle
    2. MSI GS66 Stealth 11UE-007 RAM Replacement: adım 2, 1 resimden 1.
      • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
      FixBot'a Sor
      Yorum Ekle
    3. MSI GS66 Stealth 11UE-007 RAM Replacement: adım 3, 1 resimden 1.
      • Remove eight 10 mm Phillips #1 screws.
      FixBot'a Sor
      Yorum Ekle
    4. MSI GS66 Stealth 11UE-007 RAM Replacement: adım 4, 1 resimden 1.
      • Remove one 7 mm Philips #1 screw from the center bottom of backplate.
      FixBot'a Sor
      Yorum Ekle
    5. MSI GS66 Stealth 11UE-007 RAM Replacement: adım 5, 3 resimden 1. MSI GS66 Stealth 11UE-007 RAM Replacement: adım 5, 3 resimden 2. MSI GS66 Stealth 11UE-007 RAM Replacement: adım 5, 3 resimden 3.
      • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
      • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
      FixBot'a Sor
      Yorum Ekle
    6. MSI GS66 Stealth 11UE-007 RAM Replacement: adım 6, 2 resimden 1. MSI GS66 Stealth 11UE-007 RAM Replacement: adım 6, 2 resimden 2.
      • Lift back black plastic.
      FixBot'a Sor
      Yorum Ekle
    7. MSI GS66 Stealth 11UE-007 RAM Replacement: adım 7, 2 resimden 1. MSI GS66 Stealth 11UE-007 RAM Replacement: adım 7, 2 resimden 2.
      • Place both thumbs on metal tabs and apply pressure in a widening motion until RAM lifts.
      FixBot'a Sor
      Yorum Ekle
    8. MSI GS66 Stealth 11UE-007 RAM Replacement: adım 8, 1 resimden 1.
      • Pull RAM straight out from the connector at the angle it lifted at.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alex Robinson
1.190 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 40
Her zaman: 1,033
