Ana içeriğe geç
MSI GS70 Battery Replacement
Neye ihtiyacın var
    1. MSI GS70 Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Make sure that the laptop is turned off before starting.
      • Place laptop with the bottom plate facing up.
      FixBot'a Sor
      Yorum Ekle
    2. MSI GS70 Battery Replacement: adım 2, 1 resimden 1.
      • Remove all screws using the JIS #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. MSI GS70 Battery Replacement: adım 3, 1 resimden 1.
      • Remove the back plate.
      • Locate the battery.
      FixBot'a Sor
      Yorum Ekle
    4. MSI GS70 Battery Replacement: adım 4, 1 resimden 1.
      • Locate the foil connector above the battery.
      FixBot'a Sor
      Yorum Ekle
    5. MSI GS70 Battery Replacement: adım 5, 1 resimden 1.
      • Flip up both black clips with your spudger.
      FixBot'a Sor
      Yorum Ekle
    6. MSI GS70 Battery Replacement: adım 6, 1 resimden 1.
      • Remove the foil connector by pulling on the blue tabs.
      FixBot'a Sor
      Yorum Ekle
    7. MSI GS70 Battery Replacement: adım 7, 1 resimden 1.
      • After the foil connector is removed you will see an 8 pin connector.
      • Disconnect the 8 Pin connector.
      FixBot'a Sor
      Yorum Ekle
    8. MSI GS70 Battery Replacement: adım 8, 1 resimden 1.
      • Lift the battery and remove.
      FixBot'a Sor
      Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
Perfect guide
storolle - Yanıt Paylaş
Anyone know what the foil connector is? Mine is broken, and needs to be replaced.
Jonathan Hawkes - Yanıt Paylaş
Which battery model should I buy?
slackware2007 - Yanıt Paylaş
BTY-L76 seems like a good fit
uchadhana (다나) - Yanıt Paylaş
I want to replace the battery and lcd cover of the msi gs72 6qe stealth pro. Are the msi gs70 parts compatible with the msi gs72? because I have difficulty finding msi gs72 parts in my country (indonesia)
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 49
Her zaman: 10,121
