Ana içeriğe geç
MSI GS70 Battery Replacement
Neye ihtiyacın var
  1. MSI GS70 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure that the laptop is turned off before starting.
    • Place laptop with the bottom plate facing up.
  2. MSI GS70 Battery Replacement: adım 2, 1 resimden 1.
    • Remove all screws using the JIS #1 screwdriver.
  3. MSI GS70 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the back plate.
    • Locate the battery.
  4. MSI GS70 Battery Replacement: adım 4, 1 resimden 1.
    • Locate the foil connector above the battery.
  5. MSI GS70 Battery Replacement: adım 5, 1 resimden 1.
    • Flip up both black clips with your spudger.
  6. MSI GS70 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the foil connector by pulling on the blue tabs.
  7. MSI GS70 Battery Replacement: adım 7, 1 resimden 1.
    • After the foil connector is removed you will see an 8 pin connector.
    • Disconnect the 8 Pin connector.
  8. MSI GS70 Battery Replacement: adım 8, 1 resimden 1.
    • Lift the battery and remove.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
Perfect guide
storolle - Yanıt
Anyone know what the foil connector is? Mine is broken, and needs to be replaced.
Jonathan Hawkes - Yanıt
Which battery model should I buy?
slackware2007 - Yanıt
BTY-L76 seems like a good fit
uchadhana (다나) -
I want to replace the battery and lcd cover of the msi gs72 6qe stealth pro. Are the msi gs70 parts compatible with the msi gs72? because I have difficulty finding msi gs72 parts in my country (indonesia)
uchadhana (다나) - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 9,622
