Ana içeriğe geç
MSI GS70 Battery Replacement
Neye ihtiyacın var
  1. MSI GS70 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure that the laptop is turned off before starting.
    • Place laptop with the bottom plate facing up.
  2. MSI GS70 Battery Replacement: adım 2, 1 resimden 1.
    • Remove all screws using the JIS #1 screwdriver.
    2 more screws right in the middle not marked in the pic. remember to get the one under the warranty sticker
    Dave D - Yanıt
  3. MSI GS70 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the back plate.
    • Locate the battery.
  4. MSI GS70 Battery Replacement: adım 4, 1 resimden 1.
    • Locate the foil connector above the battery.
  5. MSI GS70 Battery Replacement: adım 5, 1 resimden 1.
    • Flip up both black clips with your spudger.
  6. MSI GS70 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the foil connector by pulling on the blue tabs.
  7. MSI GS70 Battery Replacement: adım 7, 1 resimden 1.
    • After the foil connector is removed you will see an 8 pin connector.
    • Disconnect the 8 Pin connector.
  8. MSI GS70 Battery Replacement: adım 8, 1 resimden 1.
    • Lift the battery and remove.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Perfect guide
storolle - Yanıt
Anyone know what the foil connector is? Mine is broken, and needs to be replaced.
Jonathan Hawkes - Yanıt
Which battery model should I buy?
slackware2007 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 8,885
