Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using your JIS #1, locate and remove all screws from the backplate.
When all the screws are removed, proceed to remove the backplate. The hard drive will be located right next to the battery.
Locate the black rubber spacer
Remove the spacer by gently pulling the flap
Carfully lift up the Hard Drive using your Spudger.
Next, pull up your hard drive from the battery end and proceed to remove the hard drive
11 farklı kişi bu kılavuzu tamamladı.
2 Yorum
The screws on my machine were Philips not torx don't know if it is different or has changed at all but all internal and external were Phillips
bonjour
comment accéder au disque dur msata sur le msi gs 70
