Ana içeriğe geç
MSI GS70 Solid State Drive Replacement
Neye ihtiyacın var
  1. MSI GS70 Solid State Drive Replacement, Solid State Drive: adım 1, 2 resimden 1. MSI GS70 Solid State Drive Replacement, Solid State Drive: adım 1, 2 resimden 2.
    • Locate and remove all screws securing the back plate. Place the screws on the magnetic mat.
    • Locate one of the openings on the side and gently pull the back plate up to remove it.
  2. MSI GS70 Solid State Drive Replacement: adım 2, 1 resimden 1.
    • Locate the solid state drive. It is initially obscured by a connector, its okay to push away the connector to access the solid state drive.
  3. MSI GS70 Solid State Drive Replacement: adım 3, 1 resimden 1.
    • Remove the screw holding the solid state drive. Place the screw on the magnetic mat
  4. MSI GS70 Solid State Drive Replacement: adım 4, 1 resimden 1.
    • Gently remove the solid state drive.
  5. MSI GS70 Solid State Drive Replacement: adım 5, 1 resimden 1.
    • There are different form factors for solid state drives and so you have to pick the appropriate one.
    • The MSI GS70 will only accept 50mm solid state drives so buy accordingly.
  6. MSI GS70 Solid State Drive Replacement: adım 6, 1 resimden 1.
    • There is a second solid state drive right next to the first one if you want to add another solid state drive.
Sonuç
Once you have secured the solid state drive, push and screw in the back plate.
2 farklı kişi bu kılavuzu tamamladı.
Gene Abuan
310 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 47
Her zaman: 3,144
