Ana içeriğe geç
MSI GT62VR 6RD Dominator Battery Replacement
Neye ihtiyacın var
  1. MSI GT62VR 6RD Dominator Battery Replacement, Battery: adım 1, 2 resimden 1. MSI GT62VR 6RD Dominator Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the 6 screws on the bottom plate of the laptop using a Phillips driver.
  2. MSI GT62VR 6RD Dominator Battery Replacement: adım 2, 2 resimden 1. MSI GT62VR 6RD Dominator Battery Replacement: adım 2, 2 resimden 2.
    • Insert the plastic opening tool into the back plate of the laptop and lightly pry it up.
    • The laptop cover will break if it is being handled roughly.
    • Slide the plastic opening tool around the laptop's edge gently, slowly popping off the clips securing it into the laptop.
    • Remove the back plate.
  3. MSI GT62VR 6RD Dominator Battery Replacement: adım 3, 3 resimden 1. MSI GT62VR 6RD Dominator Battery Replacement: adım 3, 3 resimden 2. MSI GT62VR 6RD Dominator Battery Replacement: adım 3, 3 resimden 3.
    • Locate the battery.
    • The wires are located at the back end of the battery and covered in tape.
    • Remove the tape covering the battery connector.
    • Place your hands at the corners of the wires.
    • Pull upward from the back end of the battery where the wires are located.
    • Remove the battery.
Sonuç
Rebekah Johnson
147 İtibar
1 Kılavuz yazıldı
Bir Yorum
Can i use it using chargine cable even if i remove rhe battery?
Tabs XXIV - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,900
