Ana içeriğe geç
MSI GT62VR 6RD Dominator Cooling Fan Replacement
Neye ihtiyacın var
  1. MSI GT62VR 6RD Dominator Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 1. MSI GT62VR 6RD Dominator Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 2.
    • Remove the six 1.2mm screws on the bottom plate of the laptop using a JIS #0 screwdriver.
  2. MSI GT62VR 6RD Dominator Cooling Fan Replacement: adım 2, 3 resimden 1. MSI GT62VR 6RD Dominator Cooling Fan Replacement: adım 2, 3 resimden 2. MSI GT62VR 6RD Dominator Cooling Fan Replacement: adım 2, 3 resimden 3.
    • Insert the plastic opening tools into the seam on the back plate of the laptop.
    • A popping sound may come from your device while you remove the backplate.
    • Pry the back plate up.
    • Slide the plastic opening tool around the laptop's edge slowly until the backplate is completely removed.
  3. MSI GT62VR 6RD Dominator Cooling Fan Replacement: adım 3, 2 resimden 1. MSI GT62VR 6RD Dominator Cooling Fan Replacement: adım 3, 2 resimden 2.
    • Remove the three 2.0mm screws using the JIS #0 screwdriver.
  4. MSI GT62VR 6RD Dominator Cooling Fan Replacement: adım 4, 2 resimden 1. MSI GT62VR 6RD Dominator Cooling Fan Replacement: adım 4, 2 resimden 2.
    • The white plastic clip secures the fan wires to the laptop.
    • Unplug the white clip by grasping it and wiggling it back and forth .
    • Do not pull the clip out by the wires themselves.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adrian Nelson
270 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 17
Her zaman: 1,541
