Ana içeriğe geç
MSI GT62VR 6RD Dominator M.2 SSD Replacement
Neye ihtiyacın var
  1. MSI GT62VR 6RD Dominator M.2 SSD Replacement, M.2 SSD: adım 1, 2 resimden 1. MSI GT62VR 6RD Dominator M.2 SSD Replacement, M.2 SSD: adım 1, 2 resimden 2.
    • Remove the six 1.2mm screws on the bottom plate of the laptop using a JIS #0 screwdriver.
  2. MSI GT62VR 6RD Dominator M.2 SSD Replacement: adım 2, 3 resimden 1. MSI GT62VR 6RD Dominator M.2 SSD Replacement: adım 2, 3 resimden 2. MSI GT62VR 6RD Dominator M.2 SSD Replacement: adım 2, 3 resimden 3.
    • Insert the plastic opening tool into the seam on the backplate of the laptop.
    • A popping sound will be produced from your device while you remove the backplate.
    • Pry the back plate up.
    • Slide the plastic opening tool around the laptop's edge slowly until the backplate is completely removed.
  3. MSI GT62VR 6RD Dominator M.2 SSD Replacement: adım 3, 2 resimden 1. MSI GT62VR 6RD Dominator M.2 SSD Replacement: adım 3, 2 resimden 2.
    • Remove the single 1.2mm screw securing the SSD to the laptop using the JIS #0 screwdriver.
  4. MSI GT62VR 6RD Dominator M.2 SSD Replacement: adım 4, 2 resimden 1. MSI GT62VR 6RD Dominator M.2 SSD Replacement: adım 4, 2 resimden 2.
    • Remove the old SSD, then insert and screw in the new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Isn’t that an M.2 Drive not a GPU? the GPU is in the top right. under the heat pipes.
Will Rogers - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 1,239
