Neye ihtiyacın var
Remove the 6 screws on the bottom plate of the laptop using a Phillips driver.
Remove the six screws on the back plate of the laptop using a JIS #0 screwdriver.
Insert the plastic opening tool into the side of the laptop above the fan, and lightly pry it up.
Slide the plastic opening tool around the laptop's edge gently, while slowly popping off the clips securing it into the laptop.
Bir Yorum
this is only for the sub, the other speaker is a nightmare to replace
