Giriş
This guide will help you replace the screen of your MSI GT70 MS-1763 laptop. We will walk you through the steps to remove your screen in order to replace it.
Neye ihtiyacın var
Remove the rubber guards covering the two 3mm screws on the bottom of the screen. Next, remove the screws with a Phillips #0 screwdriver.
Bir başkası bu kılavuzu tamamladı.
