Ana içeriğe geç
MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement
Neye ihtiyacın var
  1. MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement, Hard Drive and SSD: adım 1, 2 resimden 1. MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement, Hard Drive and SSD: adım 1, 2 resimden 2.
    • Remove the seven 6mm #0 Phillips Head screws on the bottom of the device.
    • Remove the bottom to access the inside.
  2. MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement: adım 2, 2 resimden 1. MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement: adım 2, 2 resimden 2.
    • Disconnect the SATA cable from the hard drive.
  3. MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement: adım 3, 1 resimden 1.
    • Pull out the hard drive.
  4. MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement: adım 4, 2 resimden 1. MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement: adım 4, 2 resimden 2.
    • Remove the two 6mm #0 Phillips head screws securing the two SSDs.
  5. MSI GT72 2QE Dominator Pro Hard Drive and SSD Replacement: adım 5, 1 resimden 1.
    • Pull the SSDs away from its slot.
    • Be sure to pull parallel to the PCB. Do not pull upward at an angle.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Colin Harrop
164 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G2, Banghart Spring 2017 Cal Poly, Team S17-G2, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S17G2
5 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Good evening how to get a laptop battery with shipping to Saudi Arabia
rajh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 5,376
