Ana içeriğe geç
MSI MS-1782 Back Cover Replacement
Neye ihtiyacın var
  1. MSI MS-1782 Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Back Cover Replacement: adım 2, 3 resimden 1. MSI MS-1782 Back Cover Replacement: adım 2, 3 resimden 2. MSI MS-1782 Back Cover Replacement: adım 2, 3 resimden 3.
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 337
