Ana içeriğe geç
MSI MS-1782 Speaker Assembly Replacement
Neye ihtiyacın var
  1. MSI MS-1782 Speaker Assembly Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Speaker Assembly Replacement: adım 2, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement: adım 2, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement: adım 2, 3 resimden 3.
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Speaker Assembly Replacement, Cooling Assembly: adım 3, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement, Cooling Assembly: adım 3, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement, Cooling Assembly: adım 3, 3 resimden 3.
    • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
    • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
  4. MSI MS-1782 Speaker Assembly Replacement: adım 4, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement: adım 4, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement: adım 4, 3 resimden 3.
    • Gently detach the fan connector.
    • Remove the fan by lifting it out of its housing.
    • Be sure to handle the wire delicately; if not it will break.
  5. MSI MS-1782 Speaker Assembly Replacement: adım 5, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement: adım 5, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement: adım 5, 3 resimden 3.
    • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
    • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
  6. MSI MS-1782 Speaker Assembly Replacement: adım 6, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement: adım 6, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement: adım 6, 3 resimden 3.
  7. MSI MS-1782 Speaker Assembly Replacement: adım 7, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement: adım 7, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement: adım 7, 3 resimden 3.
    • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
    • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
  8. MSI MS-1782 Speaker Assembly Replacement: adım 8, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement: adım 8, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement: adım 8, 3 resimden 3.
    • Gently lift the heat sink and then pull forwards towards you.
  9. MSI MS-1782 Speaker Assembly Replacement, Battery: adım 9, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement, Battery: adım 9, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement, Battery: adım 9, 3 resimden 3.
    • Remove the four 5.5 mm screws holding the battery frame in place using a JIS #1 screwdriver.
    • Gently disconnect the cable connecting the M.2 caddy to the motherboard.
  10. MSI MS-1782 Speaker Assembly Replacement: adım 10, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement: adım 10, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement: adım 10, 3 resimden 3.
    • Remove the 3.6 mm screw holding the M.2 caddy in place using a JIS #1 screwdriver.
  11. MSI MS-1782 Speaker Assembly Replacement: adım 11, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement: adım 11, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement: adım 11, 3 resimden 3.
    • Gently disconnect the two blue ribbons.
  12. MSI MS-1782 Speaker Assembly Replacement: adım 12, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement: adım 12, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement: adım 12, 3 resimden 3.
    • Remove the 5.1 mm screw holding in the disk reader using a JIS #1 screwdriver.
    • Use an iFixit opening tool to push the back of the disk reader to push it out of the laptop's chassis.
  13. MSI MS-1782 Speaker Assembly Replacement: adım 13, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement: adım 13, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement: adım 13, 3 resimden 3.
    • Gently pull the disc reader out of the laptop.
    • Lift the plastic cover and disconnect the cable connected next to the speaker.
  14. MSI MS-1782 Speaker Assembly Replacement: adım 14, 1 resimden 1.
    • Remove the five 5 mm screws holding the frame in place using a JIS #1 screwdriver.
  15. MSI MS-1782 Speaker Assembly Replacement: adım 15, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement: adım 15, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement: adım 15, 3 resimden 3.
    • Pry up on the battery frame with an opening tool and unclip from the main chassis, working your way around the laptop.
    • To remove the battery, pry up on it to unstick the adhesive.
    • A little Isopropyl alcohol under the battery can help unstick it from the frame.
  16. MSI MS-1782 Speaker Assembly Replacement, Speaker Assembly: adım 16, 2 resimden 1. MSI MS-1782 Speaker Assembly Replacement, Speaker Assembly: adım 16, 2 resimden 2.
    • Pull the left speaker out, following the wire, unclipping it as you go to the next.
  17. MSI MS-1782 Speaker Assembly Replacement: adım 17, 2 resimden 1. MSI MS-1782 Speaker Assembly Replacement: adım 17, 2 resimden 2.
    • Pull the right speaker out. Unclip the wire as you go, now completely removing both speakers.
  18. MSI MS-1782 Speaker Assembly Replacement: adım 18, 3 resimden 1. MSI MS-1782 Speaker Assembly Replacement: adım 18, 3 resimden 2. MSI MS-1782 Speaker Assembly Replacement: adım 18, 3 resimden 3.
    • Unplug the subwoofer and lift vertically to remove.
Sonuç
A'kia
193 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 23
Her zaman: 119
