Ana içeriğe geç
MSI PE70 6QE-035US RAM Replacement
Neye ihtiyacın var
  1. MSI PE70 6QE-035US RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Start by flipping the device over to the backside.
    • Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
  2. MSI PE70 6QE-035US RAM Replacement: adım 2, 3 resimden 1. MSI PE70 6QE-035US RAM Replacement: adım 2, 3 resimden 2. MSI PE70 6QE-035US RAM Replacement: adım 2, 3 resimden 3.
    • After you remove the back panel, you should now see the RAM
    • Pull the tabs holding in the RAM outwards. The RAM sticks should pop slightly outward and can now be removed.
  3. MSI PE70 6QE-035US RAM Replacement: adım 3, 1 resimden 1.
    • Pull out RAM sticks, and set aside.
  4. MSI PE70 6QE-035US RAM Replacement: adım 4, 1 resimden 1.
    • Repeat the same process for the second RAM stick.
Sonuç
To reassemble your device, follow these instructions in reverse order
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 110
