Giriş
Are you having trouble running programs and require a RAM replacement? Or maybe just looking to replace your current RAM sticks with others? This guide will show you all the steps on how to do so. All you will need is the J0 size bit, an Ifixit screwdriver, and any hard surface ground or area that will not create static electricity.
Neye ihtiyacın var
Start by flipping the device over to the backside.
Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
To reassemble your device, follow these instructions in reverse order
2 farklı kişi bu kılavuzu tamamladı.
