Ana içeriğe geç
MSI PE70 6QE-035US speaker Replacement
Neye ihtiyacın var
  1. MSI PE70 6QE-035US speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Start by flipping the device over to the backside.
    • Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
  2. MSI PE70 6QE-035US speaker Replacement: adım 2, 2 resimden 1. MSI PE70 6QE-035US speaker Replacement: adım 2, 2 resimden 2.
    • After you remove the back panel, you should now see the 3 speakers.
    • We will start with the bottom most speaker.
  3. MSI PE70 6QE-035US speaker Replacement: adım 3, 2 resimden 1. MSI PE70 6QE-035US speaker Replacement: adım 3, 2 resimden 2.
    • Using the ifixit opening tool, remove the speaker by gently unplugging its cord from the motherboard. Be sure to unplug the cord in the direction shown by the arrow.
    • After the cord has been unplugged, the speaker should now be able to be lifted out.
  4. MSI PE70 6QE-035US speaker Replacement: adım 4, 3 resimden 1. MSI PE70 6QE-035US speaker Replacement: adım 4, 3 resimden 2. MSI PE70 6QE-035US speaker Replacement: adım 4, 3 resimden 3.
    • These two speakers will be taken out together because they are held in by the same cord.
    • Once you have unplugged the cord, both speakers should be able to be lifted out.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 66
