Ana içeriğe geç
MSI PR600 MS-16372 RAM Replacement
Neye ihtiyacın var
  1. MSI PR600 MS-16372 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • First, turn off the computer and unplug the power cord.
    • If laptop is not unplugged from the power cord, you could be at risk of electric shock.
    FixBot'a Sor
    Yorum Ekle
  2. MSI PR600 MS-16372 RAM Replacement: adım 2, 1 resimden 1.
    • Flip laptop over so that you are looking at the bottom of the laptop.
    • Put your left pointer finger on the switch labeled "Battery lock" and your right pointer finger on the switch labeled "Release".
    FixBot'a Sor
    Yorum Ekle
  3. MSI PR600 MS-16372 RAM Replacement: adım 3, 1 resimden 1.
    • Switch the tab labeled "Battery lock" to the unlocked position.
    • Slide the tab labeled "Release" to the right and hold it down.
    • While holding the "Release" tab to the right, slide the battery out with your left hand.
    FixBot'a Sor
    Yorum Ekle
  4. MSI PR600 MS-16372 RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Unscrew the four 10 mm Phillips head screws circled in red in the picture using the Phillips 00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. MSI PR600 MS-16372 RAM Replacement: adım 5, 1 resimden 1.
    • Put your pointer finger underneath the tab and lift up to remove the plastic cover.
    FixBot'a Sor
    Yorum Ekle
  6. MSI PR600 MS-16372 RAM Replacement: adım 6, 1 resimden 1.
    • Slide the RAM off by pulling it away from the fan.
    • Slide RAM back in to serve as a reset.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lauren Mewes
388 İtibar
3 adet Kılavuz yazıldı
Ekip
UC Davis, Team S4-G8, Lore Fall 2018 UC Davis, Team S4-G8, Lore Fall 2018 üyesi
UCD-LORE-F18S4G8
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 748
