Aletler
Parçalar
Hiçbir parça belirtilmedi.
First things first : you'll need a reasonably dead Mac Cube power supply
The only way to access these clips is through the ventilation holes, .. how convenient !
It's enough to unhook 1 clip per side, and one of the clips cannot be unhooked, as it's blocked by some black paper plastic rubber thingy
In case you have something thin and strong enough to do this without enlarging the holes: please leave a comment down below !
I drilled through the existing holes to make them large enough for a fittingly stiff screw driver
Now, the last step is to unhook the two halves of the metal chassis from each other - with the correct motion, this happens very easily
Firmly press on the top half (the bottom has the PCB laying right against it) whilst prising with a flat-head screw driver at the seam: there's 3 metal clips to unhook on each side
And you're done !
Congrats !
Congrats !
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Excellent walk-through of the steps, with very kind and generous warnings. I found this VERY helpful, as I own two working G4 Cubes, with no power supplies. I’m looking for broken “bricks” to repair and finally re-use my Cubes.
Thanks mate ! This will help to get my Cube alive again : -)
