Ana içeriğe geç
Mac Cube G4 205W Power Supply Disassembly
Neye ihtiyacın var
  1. Mac Cube G4 205W Power Supply Disassembly, Mac Cube G4 205W Power Supply Disassembly: adım 1, 1 resimden 1.
    • First things first : you'll need a reasonably dead Mac Cube power supply
  2. Mac Cube G4 205W Power Supply Disassembly: adım 2, 3 resimden 1. Mac Cube G4 205W Power Supply Disassembly: adım 2, 3 resimden 2. Mac Cube G4 205W Power Supply Disassembly: adım 2, 3 resimden 3.
    • The first step is to separate these two end-caps
    • Each of them has 2 very strong (and equally brittle) clips holding it in place
  3. Mac Cube G4 205W Power Supply Disassembly: adım 3, 1 resimden 1.
    • The only way to access these clips is through the ventilation holes, .. how convenient !
    • It's enough to unhook 1 clip per side, and one of the clips cannot be unhooked, as it's blocked by some black paper plastic rubber thingy
    • It is highly recommended you go in through the marked holes (those are the largest open areas inside the PSU anyway)
    • In case you have something thin and strong enough to do this without enlarging the holes: please leave a comment down below !
    • I drilled through the existing holes to make them large enough for a fittingly stiff screw driver
    • BEWARE : this plastic is incredibly brittle and will crack very easily; using a stepped drill bit for the plastic, then a regular bit for the metal worked best
  4. Mac Cube G4 205W Power Supply Disassembly: adım 4, 2 resimden 1. Mac Cube G4 205W Power Supply Disassembly: adım 4, 2 resimden 2.
    • Once you've enlarged your holes, it's just a matter of carefully prising these clips free
    • Again, be careful, they're very brittle
    • Since peeping through a 3mm hole doesn't give one the best visibility, here's also a photo of the power supply board, so you know what to look out for ;)
  5. Mac Cube G4 205W Power Supply Disassembly: adım 5, 1 resimden 1.
    • Correctly assuming you've gotten rid of all the plastic surrounding the metal chassis, it's high time to open a bottle of something !
    • Unclip metallic end-caps with a relatively skinny flat-head screw driver
  6. Mac Cube G4 205W Power Supply Disassembly: adım 6, 1 resimden 1.
    • Now, the last step is to unhook the two halves of the metal chassis from each other - with the correct motion, this happens very easily
    • Firmly press on the top half (the bottom has the PCB laying right against it) whilst prising with a flat-head screw driver at the seam: there's 3 metal clips to unhook on each side
    • And you're done !
    • Feel free to share what problem yours had and how you've fixed it down in the comments :)
Sonuç
Congrats !
2 farklı kişi bu kılavuzu tamamladı.
Darie H
4.580 İtibar
5 adet Kılavuz yazıldı
2 Yorum
Excellent walk-through of the steps, with very kind and generous warnings. I found this VERY helpful, as I own two working G4 Cubes, with no power supplies. I’m looking for broken “bricks” to repair and finally re-use my Cubes.
Scott Peaker - Yanıt
Thanks mate ! This will help to get my Cube alive again : -)
Pumpkin Eater - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 36
Her zaman: 1,729
