Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. Mac mini (2024) cihazınızı onarmak için, servis kılavuzumuzu kullanın.
    1. Mac Mini (2024) Chip ID, Main Board Side 1: adım 1, 2 resimden 1. Mac Mini (2024) Chip ID, Main Board Side 1: adım 1, 2 resimden 2.
      • Apple APL1206/339S01548 E M4 deca-core applications processor w/ GPU
      • Micron MT62F1G64D4AS-026 XT:C 8 GB LPDDR5 SDRAM Memory
      • Apple APL1066/343S00710 power management
      • Apple APL1067/343S00683 ? power management
      • Likely Apple U0P4F7-Y2 Thunderbolt 4 controller
      • Winbond W25Q64NE 8 MB serial NOR flash memory
      • Likely Infineon CYUSB2408 USB level shifter
      FixBot'a Sor
      Yorum Ekle
    2. Mac Mini (2024) Chip ID, Main Board Side 1: adım 2, 1 resimden 1.
      • Winbond W25X40CL 4 Mb serial NOR flash memory
      • Texas Instruments TPS628502 2 A / adj. step-down converter
      • Analog Devices DC-DC converter
      • Texas Instruments TPS715A01 80 mA / adj. LDO regulator
      • Texas Instruments TPS2559 power distribution switch
      • Texas Instruments INA190A2 bidirectional current sense amplifier
      • Texas Instruments TLV7021 single comparator
      FixBot'a Sor
      Yorum Ekle
    3. Mac Mini (2024) Chip ID: adım 3, 2 resimden 1. Mac Mini (2024) Chip ID: adım 3, 2 resimden 2.
      • Likely Parade Technologies PS190 DisplayPort to HDMI converter
      • Genesys Logic GL3590-TBYS2 3 USB Type-C SuperSpeed+ & 3 USB Type-A SuperSpeed+ hub controller
      • Macronix MX25V2035FZUI 2 Mb serial NOR flash memory
      • Texas Instruments SN26A23 USB Type-C controller
      • GigaDevice GD25Q80E 1 MB serial NOR flash memory
      • Broadcom BCM57762 gigabit ethernet controller
      FixBot'a Sor
      Yorum Ekle
    4. Mac Mini (2024) Chip ID: adım 4, 1 resimden 1.
      • Apple APL5791/343S00709 power management
      • Renesas multiphase controller
      • Cirrus Logic CS42L84A audio codec
      • Texas Instruments SN012776B0 audio amplifier
      • Texas Instruments TPS621371 step-down converter
      • Likely Renesas PWM DC-DC converter controller
      FixBot'a Sor
      Yorum Ekle
    5. Mac Mini (2024) Chip ID: adım 5, 1 resimden 1.
      • onsemi NCP380LMU05AATBG power distribution switch
      • Likely Renesas mixed signal array
      • Texas Instruments TLV75801P 500 mA / adj. LDO regulator
      • Texas Instruments INA190A3 bidirectional current sense amplifier
      • Texas Instruments TLV7011 single comparator
      • Texas Instruments TLV9051 single operational amplifier
      FixBot'a Sor
      Yorum Ekle
    6. Mac Mini (2024) Chip ID, Flash Module (NAND) Side 1: adım 6, 2 resimden 1. Mac Mini (2024) Chip ID, Flash Module (NAND) Side 1: adım 6, 2 resimden 2.
      • SanDisk SDMVGKLK2 128G 128 GB NAND flash
      FixBot'a Sor
      Yorum Ekle
    7. Mac Mini (2024) Chip ID, Flash Module (NAND) Side 2: adım 7, 2 resimden 1. Mac Mini (2024) Chip ID, Flash Module (NAND) Side 2: adım 7, 2 resimden 2.
      • Apple 338S00600-A0 power management
      • Texas Instruments TPS62180 6 A synchronous buck converter
      FixBot'a Sor
      Yorum Ekle
    8. Mac Mini (2024) Chip ID, Wireless Board: adım 8, 2 resimden 1. Mac Mini (2024) Chip ID, Wireless Board: adım 8, 2 resimden 2.
      • Likely USI 339S01162 Bluetooth & WiFi module
      FixBot'a Sor
      Yorum Ekle
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 113
Son 30 gün: 514
Her zaman: 16,537
