Ana içeriğe geç
Mac Mini Mid 2010 Fan Replacement
Neye ihtiyacın var
    1. Mac Mini Mid 2010 Fan Replacement, Bottom Cover: adım 1, 2 resimden 1. Mac Mini Mid 2010 Fan Replacement, Bottom Cover: adım 1, 2 resimden 2.
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      FixBot'a Sor
      Yorum Ekle
    2. Mac Mini Mid 2010 Fan Replacement: adım 2, 1 resimden 1.
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
      FixBot'a Sor
      Yorum Ekle
    1. Mac Mini Mid 2010 Fan Replacement, Fan: adım 3, 1 resimden 1.
      • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
      FixBot'a Sor
      Yorum Ekle
    2. Mac Mini Mid 2010 Fan Replacement: adım 4, 1 resimden 1.
      • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
      • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
      FixBot'a Sor
      Yorum Ekle
    3. Mac Mini Mid 2010 Fan Replacement: adım 5, 1 resimden 1.
      • Lift the fan out of the mini for enough clearance to access its connector.
      • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
      • Remove the fan.
      FixBot'a Sor
      Yorum Ekle
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
How do you know the order of the wires when placing the 4 wires back onto the motherboard?
Communications Department - Yanıt Paylaş
The connector is a snap in / snap out or more properly lift out connector. The connector goes back in only one way with the 4 pins aimed towards the wifi icon. To get it out you GENTLY lift the wires. I used my fingernail under the wires as they went from the fan into the connector.
Mike Stark - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 26
Son 30 gün: 128
Her zaman: 17,838
