Ana içeriğe geç
Mac Pro First Generation GPU Replacement
  1. Mac Pro First Generation GPU Replacement, Case Panel: adım 1, 1 resimden 1.
    • Lift the lever to unlock the case.
    FixBot'a Sor
    Yorum Ekle
  2. Mac Pro First Generation GPU Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
    FixBot'a Sor
    Yorum Ekle
  3. Mac Pro First Generation GPU Replacement, GPU (Graphics Card): adım 3, 1 resimden 1.
    • Locate the graphics card in the open panel side of your Mac Pro.
    FixBot'a Sor
    Yorum Ekle
  4. Mac Pro First Generation GPU Replacement: adım 4, 3 resimden 1. Mac Pro First Generation GPU Replacement: adım 4, 3 resimden 2. Mac Pro First Generation GPU Replacement: adım 4, 3 resimden 3.
    • Unscrew the two thumb screws by twisting counterclockwise using your fingers until the slide lock is released.
    • Remove the slide lock.
    FixBot'a Sor
    Yorum Ekle
  5. Mac Pro First Generation GPU Replacement: adım 5, 3 resimden 1. Mac Pro First Generation GPU Replacement: adım 5, 3 resimden 2. Mac Pro First Generation GPU Replacement: adım 5, 3 resimden 3.
    • Push up on the clip directly behind the graphics card to release it from its slot.
    • Slide the graphics card out of the slot using both hands by firmly holding the corners of the top of the card as shown.
    • Handle the card only by its edges. Don't touch any exposed components or connectors.
    FixBot'a Sor
    Yorum Ekle
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
Andrew Kim
1.263 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014 üyesi
CPSU-MANESS-F14S6G24
4 Üyeler
25 adet Kılavuz yazıldı
8Kılavuz Yorumları
I have a first generation Mac Pro (1,1 – 2 x 3GHz Dual-Core Intel Xeon) that I purchased in November 2007.
I still love it.
THANK YOU for your valuable User Guides, and parts replacement guides!
David R Purnell - Yanıt Paylaş
Hi, I just installed Mac OS X High Sierra in my 2010 Mac Pro. The first monitor is active with the ATI Radeon HD5770. However the #2 screen is inactive with its ATI Radeon HD3870. Should I get another HD5770 or a different card so I can use the second screen?
Robert Lloyd - Yanıt Paylaş
For starters this is the first generation forum while your 2010 is a fifth generation model.
Nevertheless I had an interesting situation with the 5770 in a first gen machine that only ran under strange circumstances—a situation wroth sharing nevertheless.:
Ati Radeon X1900Xt had to be installed on bay 1 for the 5770 to work on bay 4
But for your situation, the question is: does the 3870 work standalone in its bay if the 5770 is taken out completely?
And if you swap the graphics cards into each others’ position, what’s the result?
allenwilson33 - Yanıt Paylaş
Hi. My 1st Gen Mac Pro is maxed out with OS X Lion 10.7. I heard I may be able to make it a 5th Gen by switching a chip. Is anyone familiar with this?
Harold L. Watkins - Yanıt Paylaş
Hi, I have a first generation MacBook Pro which is maxed out with OS X Lion 10.7. I heard I may be able to upgrade it to a generation 5 by switching out a chip. Is anyone familiar with this?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 85
Her zaman: 23,901
