Ana içeriğe geç
Mac Pro First Generation Optical Drive Replacement
Neye ihtiyacın var
  1. Mac Pro First Generation Optical Drive Replacement, Optical Drive: adım 1, 1 resimden 1.
    • Lift the lever to unlock the case
  2. Mac Pro First Generation Optical Drive Replacement: adım 2, 1 resimden 1.
    • Remove the side panel of the Mac Pro
  3. Mac Pro First Generation Optical Drive Replacement: adım 3, 3 resimden 1. Mac Pro First Generation Optical Drive Replacement: adım 3, 3 resimden 2. Mac Pro First Generation Optical Drive Replacement: adım 3, 3 resimden 3.
    • Firmly grasp the handles of the shown compartment and pull out firmly to remove the optical drive bay.
  4. Mac Pro First Generation Optical Drive Replacement: adım 4, 1 resimden 1.
    • Firmly hold each of the two connectors and pull them out of their respective sockets.
  5. Mac Pro First Generation Optical Drive Replacement: adım 5, 2 resimden 1. Mac Pro First Generation Optical Drive Replacement: adım 5, 2 resimden 2.
    • Unscrew the shown two 6-32 type screws on each side of the optical drive.
  6. Mac Pro First Generation Optical Drive Replacement: adım 6, 2 resimden 1. Mac Pro First Generation Optical Drive Replacement: adım 6, 2 resimden 2.
    • Firmly grasp the optical drive and pull it out of its enclosure.
    To make the pull easier without pluming the whole body over- pull with your fingers and brace your thumbs on the tower chassis above - worked for me.
    Nick Rogers - Yanıt
    Correction, for pluming read pulling!
    Nick Rogers - Yanıt
Sonuç
21 farklı kişi bu kılavuzu tamamladı.
Derek Chan
1.416 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014 üyesi
CPSU-MANESS-F14S6G24
4 Üyeler
13 adet Kılavuz yazıldı
10 Yorum
Thanks! It had been a long time since I'd been inside my towers! Easy-peasy!
Janie Wilson-Cook - Yanıt
I am having problems with the new optical drive not being able to eject and close without my help. Any thoughts?
footeking - Yanıt
Did you take off the front of the tray?
nbeijer -
Awesome!!! Worked like a charm! Drive is totally busted. Do you have a link or a suggestion for an optical drive for a late 2009 Mac pro? Thanks either way!
Jay Haser - Yanıt
The unit holding the optical drive will NOT pull out at all and I and really pulling on it and wiggling it. All other videos show it popping out with little force. What am I doing wrong?
pipevape - Yanıt
I am having the same problem did you figure out what was wrong?
Tony Bounsall -
Probably just stuck. I’ve had mine out several times before, but the lever at the back of the case must be open. When it’s closed, it locks it in.
Aquenon -
I am having the same problem . I raised the lever handle no problem---Is there another interlock ?
Chuck Hendricks -
I am having the same problem. The lever arm comes up and stays up no Problem. Is there another interlock to release the optical drive door ?
vamochuck@gmail.com
Chuck Hendricks -
I am having the same problem. Any solution ?
vamochuck@gmail.com
Chuck Hendricks -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 57
Her zaman: 16,729
