Ana içeriğe geç
Mac Pro First Generation RAM Replacement
  1. Mac Pro First Generation RAM Replacement, Case Panel: adım 1, 1 resimden 1.
    • Lift the lever to unlock the case.
    FixBot'a Sor
    Yorum Ekle
  2. Mac Pro First Generation RAM Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
    FixBot'a Sor
    Yorum Ekle
  3. Mac Pro First Generation RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Locate the two RAM trays at the bottom of the Mac Pro.
    FixBot'a Sor
    Yorum Ekle
  4. Mac Pro First Generation RAM Replacement: adım 4, 2 resimden 1. Mac Pro First Generation RAM Replacement: adım 4, 2 resimden 2.
    • Pull the RAM tray out of the case by using both hands holding the edge of the ram board as shown.
    • Make sure you give enough time for the computer to cool down before you remove any internal hardware parts.
    FixBot'a Sor
    Yorum Ekle
  5. Mac Pro First Generation RAM Replacement: adım 5, 3 resimden 1. Mac Pro First Generation RAM Replacement: adım 5, 3 resimden 2. Mac Pro First Generation RAM Replacement: adım 5, 3 resimden 3.
    • Push down on the ejectors on each side of a ram stick firmly and lift the RAM stick straight out carefully by holding each side.
    • To insert a new RAM stick, place the RAM into the slot with the correct orientation and push on the stick using both hands until the ejectors are clicked into place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
Andrew Kim
1.263 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014 üyesi
CPSU-MANESS-F14S6G24
4 Üyeler
25 adet Kılavuz yazıldı
2Kılavuz Yorumları
What is the name/or type of memory chip to use in the MacPro 2008.
Curtis - Yanıt Paylaş
Hi Curtis, hope you found the RAM type ok.
Basically server RAM, ECC, 667Mhz, FB always in Pairs.
Retired Apple, PC etc engineer.
coopernewlyn - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 84
Her zaman: 22,093
