Giriş
Use this guide to replace the AirPort antenna array in your Mac Pro.
Neye ihtiyacın var
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly.
Remove the fan assembly lid.
Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
Remove the three 3.7 mm T4 screws securing the antenna array to the fan assembly.
3 farklı kişi bu kılavuzu tamamladı.
