Ana içeriğe geç
Mac Pro Late 2013 Interconnect Board Replacement
Neye ihtiyacın var
    1. Mac Pro Late 2013 Interconnect Board Replacement, Outer Case: adım 1, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement, Outer Case: adım 1, 2 resimden 2.
      • Slide the lock switch to the right, to the unlocked position.
      FixBot'a Sor
      Yorum Ekle
    2. Mac Pro Late 2013 Interconnect Board Replacement: adım 2, 3 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 2, 3 resimden 2. Mac Pro Late 2013 Interconnect Board Replacement: adım 2, 3 resimden 3.
      • Lift the outer case straight up off the Mac Pro.
      • It may help to push down on the center of the fan while lifting the case up.
      FixBot'a Sor
      Yorum Ekle
    1. Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: adım 3, 3 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: adım 3, 3 resimden 2. Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: adım 3, 3 resimden 3.
      • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Mac Pro Late 2013 Interconnect Board Replacement: adım 4, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 4, 2 resimden 2.
      • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
      • Tilt the assembly up away from the IO board.
      • Do not try to remove the fan assembly yet, as it is still attached by two cables.
      FixBot'a Sor
      Yorum Ekle
    3. Mac Pro Late 2013 Interconnect Board Replacement: adım 5, 1 resimden 1.
      • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
      • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
      FixBot'a Sor
      Yorum Ekle
    4. Mac Pro Late 2013 Interconnect Board Replacement: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
      FixBot'a Sor
      Yorum Ekle
    5. Mac Pro Late 2013 Interconnect Board Replacement: adım 7, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 7, 2 resimden 2.
      • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
      FixBot'a Sor
      Yorum Ekle
    6. Mac Pro Late 2013 Interconnect Board Replacement: adım 8, 1 resimden 1.
      • Disconnect the fan assembly antenna cable from the IO board.
      • Remove the fan assembly from the Mac Pro.
      FixBot'a Sor
      Yorum Ekle
    1. Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: adım 9, 3 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: adım 9, 3 resimden 2. Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: adım 9, 3 resimden 3.
      • Flip the Mac Pro upside down, 180 degrees.
      • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
      FixBot'a Sor
      Yorum Ekle
    2. Mac Pro Late 2013 Interconnect Board Replacement: adım 10, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 10, 2 resimden 2.
      • Carefully lift the lower case up and remove it from the Mac Pro.
      FixBot'a Sor
      Yorum Ekle
    1. Mac Pro Late 2013 Interconnect Board Replacement, Interconnect Board: adım 11, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement, Interconnect Board: adım 11, 2 resimden 2.
      • Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
      FixBot'a Sor
      Yorum Ekle
    2. Mac Pro Late 2013 Interconnect Board Replacement: adım 12, 3 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 12, 3 resimden 2. Mac Pro Late 2013 Interconnect Board Replacement: adım 12, 3 resimden 3.
      • Gently separate the other side as well.
      • Flip the connector up and out of the way of the graphics card.
      • Repeat this procedure on the other graphics card.
      FixBot'a Sor
      Yorum Ekle
    3. Mac Pro Late 2013 Interconnect Board Replacement: adım 13, 1 resimden 1.
      • Remove the two 6.0 mm T8 Torx screws securing the interconnect board to the heat sink.
      FixBot'a Sor
      Yorum Ekle
    4. Mac Pro Late 2013 Interconnect Board Replacement: adım 14, 3 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 14, 3 resimden 2. Mac Pro Late 2013 Interconnect Board Replacement: adım 14, 3 resimden 3.
      • Gently walk the interconnect board straight up off the logic board's slot connection.
      • It is recommended to lift one side and then the other.
      • Do not try to remove the interconnect board from the Mac Pro yet, as it is still connected to the IO board.
      FixBot'a Sor
      Yorum Ekle
    5. Mac Pro Late 2013 Interconnect Board Replacement: adım 15, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 15, 2 resimden 2.
      • Flip the interconnect board up and over, exposing the IO board data cable.
      • Use the same sort of twisting and spreading motion with the flat end of a spudger to separate one side of the IO board data cable.
      FixBot'a Sor
      Yorum Ekle
    6. Mac Pro Late 2013 Interconnect Board Replacement: adım 16, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 16, 2 resimden 2.
      • Use the flat end of a spudger to separate the other side of the IO board data cable.
      • Bend the cable out of the way and remove the interconnect board from the Mac Pro.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
515.439 İtibar
406 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
46.822 adet Kılavuz yazıldı
5Kılavuz Yorumları
Why is it necessary to remove the fan?
johnsburdett - Yanıt Paylaş
I'm asking me the same question. Maybe it's for protecting the upper part and to have a stable stand when turning it around to remove the bottom part. I need to access the EFI Chip in the near future, I will see then.
Kris Wood - Yanıt Paylaş
Hola necesito comprar esta placa de interconexión, donde puedo encontrarla? Saludos
RailabMac - Yanıt Paylaş
excellent, thank you very much, I wanted to ask you where I can get this plate, what is the reference?
Asdrubal - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 46
Her zaman: 7,585
