Ana içeriğe geç
Mac Pro Late 2013 Interconnect Board Replacement
Neye ihtiyacın var
  1. Mac Pro Late 2013 Interconnect Board Replacement, Outer Case: adım 1, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement, Outer Case: adım 1, 2 resimden 2.
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 Interconnect Board Replacement: adım 2, 3 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 2, 3 resimden 2. Mac Pro Late 2013 Interconnect Board Replacement: adım 2, 3 resimden 3.
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: adım 3, 3 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: adım 3, 3 resimden 2. Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: adım 3, 3 resimden 3.
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
  4. Mac Pro Late 2013 Interconnect Board Replacement: adım 4, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 4, 2 resimden 2.
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 Interconnect Board Replacement: adım 5, 1 resimden 1.
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
  6. Mac Pro Late 2013 Interconnect Board Replacement: adım 6, 1 resimden 1.
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 Interconnect Board Replacement: adım 7, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 Interconnect Board Replacement: adım 8, 1 resimden 1.
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
  9. Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: adım 9, 3 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: adım 9, 3 resimden 2. Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: adım 9, 3 resimden 3.
    • Flip the Mac Pro upside down, 180 degrees.
    • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
  10. Mac Pro Late 2013 Interconnect Board Replacement: adım 10, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 10, 2 resimden 2.
    • Carefully lift the lower case up and remove it from the Mac Pro.
  11. Mac Pro Late 2013 Interconnect Board Replacement, Interconnect Board: adım 11, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement, Interconnect Board: adım 11, 2 resimden 2.
    • Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
  12. Mac Pro Late 2013 Interconnect Board Replacement: adım 12, 3 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 12, 3 resimden 2. Mac Pro Late 2013 Interconnect Board Replacement: adım 12, 3 resimden 3.
    • Gently separate the other side as well.
    • Flip the connector up and out of the way of the graphics card.
    • Repeat this procedure on the other graphics card.
  13. Mac Pro Late 2013 Interconnect Board Replacement: adım 13, 1 resimden 1.
    • Remove the two 6.0 mm T8 Torx screws securing the interconnect board to the heat sink.
  14. Mac Pro Late 2013 Interconnect Board Replacement: adım 14, 3 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 14, 3 resimden 2. Mac Pro Late 2013 Interconnect Board Replacement: adım 14, 3 resimden 3.
    • Gently walk the interconnect board straight up off the logic board's slot connection.
    • It is recommended to lift one side and then the other.
    • Do not try to remove the interconnect board from the Mac Pro yet, as it is still connected to the IO board.
  15. Mac Pro Late 2013 Interconnect Board Replacement: adım 15, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 15, 2 resimden 2.
    • Flip the interconnect board up and over, exposing the IO board data cable.
    • Use the same sort of twisting and spreading motion with the flat end of a spudger to separate one side of the IO board data cable.
  16. Mac Pro Late 2013 Interconnect Board Replacement: adım 16, 2 resimden 1. Mac Pro Late 2013 Interconnect Board Replacement: adım 16, 2 resimden 2.
    • Use the flat end of a spudger to separate the other side of the IO board data cable.
    • Bend the cable out of the way and remove the interconnect board from the Mac Pro.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
502.855 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
4 Yorum
Why is it necessary to remove the fan?
johnsburdett - Yanıt
Hola necesito comprar esta placa de interconexión, donde puedo encontrarla? Saludos
RailabMac - Yanıt
excellent, thank you very much, I wanted to ask you where I can get this plate, what is the reference?
Asdrubal - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 46
Her zaman: 5,478
