Giriş
How to remove the upper case.
Parçalar
Hiçbir parçaya gerek yok.
  1. Power down your Mac mini, disconnect all of the cables, and flip it over. Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
  2. Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount. There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing. There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Once you have the first side free, rotate the Mac mini and start prying up on the front edge. Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  5. You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time. You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  6. Keep working around the perimeter, freeing the clips along the final edge. Keep working around the perimeter, freeing the clips along the final edge.
    • Keep working around the perimeter, freeing the clips along the final edge.
  7. Flip the Mac mini back over and lift the top housing off of the lower housing. Flip the Mac mini back over and lift the top housing off of the lower housing.
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
iRobot
1 İtibar
623 adet Kılavuz yazıldı
Bir Yorum
those Putty Knifes are:
too smal
too sharp
too expensive.
Better use a 100mm broad Spatula; (opens all the claws in on step)
out of plastic is good enough and cheap.
And use two of them at one time.
spatula - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 4
Son 30 Gün: 16
Her zaman: 9,486
