Ana içeriğe geç
Mac mini (PowerPC) Mass Storage Unit Replacement
Neye ihtiyacın var
    1. Mac mini (PowerPC) Mass Storage Unit Replacement, Top Housing: adım 1, 2 resimden 1. Mac mini (PowerPC) Mass Storage Unit Replacement, Top Housing: adım 1, 2 resimden 2.
      • Power down your Mac mini, disconnect all of the cables, and flip it over.
      • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
      • The Jimmy should reach a stop about 3/8" down.
      FixBot'a Sor
      Yorum Ekle
    2. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 2, 3 resimden 1. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 2, 3 resimden 2. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 2, 3 resimden 3.
      • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
      • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
      FixBot'a Sor
      Yorum Ekle
    3. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 3, 2 resimden 1. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 3, 2 resimden 2.
      • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
      • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
      FixBot'a Sor
      Yorum Ekle
    4. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 4, 2 resimden 1. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 4, 2 resimden 2.
      • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
      FixBot'a Sor
      Yorum Ekle
    5. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 5, 2 resimden 1. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 5, 2 resimden 2.
      • Keep working around the perimeter, freeing the clips along the final edge.
      FixBot'a Sor
      Yorum Ekle
    6. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 6, 2 resimden 1. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 6, 2 resimden 2.
      • Flip the Mac mini back over and lift the top housing off of the lower housing.
      FixBot'a Sor
      Yorum Ekle
    1. Mac mini (PowerPC) Mass Storage Unit Replacement, Mass Storage Unit: adım 7, 1 resimden 1.
      • If your mini does not have Airport installed, then skip this step.
      • Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
      FixBot'a Sor
      Yorum Ekle
    2. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 8, 1 resimden 1.
      • Remove the yellow tape securing the power button cable to the black plastic framework.
      FixBot'a Sor
      Yorum Ekle
    3. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 9, 1 resimden 1.
      • Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
      FixBot'a Sor
      Yorum Ekle
    4. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 10, 1 resimden 1.
      • Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
      FixBot'a Sor
      Yorum Ekle
    5. Mac mini (PowerPC) Mass Storage Unit Replacement: adım 11, 1 resimden 1.
      • If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
      • With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
      FixBot'a Sor
      Yorum Ekle
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
1Rehber Yorum
great guide, removing the casing at the start requires some force. thanks for posting
paul martin - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 45
Her zaman: 26,706
