Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Mac mini Late 2012 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Mac mini Late 2012 Teardown, Mac mini Late 2012 Teardown: adım 1, 1 resimden 1.
    • Good things come in mini packages. This mini is packing:
    • 2.5 GHz dual-core Intel Core i5 or 2.3 GHz quad-core Intel Core i7
    • 500 GB hard drive or 1 TB hard drive configurable to a 1 TB Fusion Drive or 256 GB solid-state drive—upgradable with an extra hard drive or SSD using our dual hard drive kit
    • 4 GB, 8 GB, or 16 GB of DDR3 SDRAM
    • Intel HD Graphics 4000
    • Thunderbolt and HDMI ports
    • SDXC card slot
    • This mini lacks an optical drive, just like its predecessor.
  2. Mac mini Late 2012 Teardown: adım 2, 2 resimden 1. Mac mini Late 2012 Teardown: adım 2, 2 resimden 2.
    • It's beginning to feel like Groundhog Day. The same model number (A1347) has graced the 2011 and 2010 minis.
    • The port layout is consistent with last year's model:
    • 10/100/1000BASE-T Ethernet
    • FireWire 800
    • HDMI (HDMI to DVI adapter included)
    • Thunderbolt (supports high-speed I/O and Mini DisplayPort)
    • Four USB 3.0 ports (an upgrade from last year's 2.0)
    • SDXC card reader
  3. Mac mini Late 2012 Teardown: adım 3, 3 resimden 1. Mac mini Late 2012 Teardown: adım 3, 3 resimden 2. Mac mini Late 2012 Teardown: adım 3, 3 resimden 3.
    • Twist and shout!
    • A simple twist of the bottom cover and we're in. That is plus one for repairability.
    • Upgradeable RAM!! Oh, how we've missed you!
    • The 2012 iteration of the Mac mini is equipped with PC3-12800 DDR3 RAM.
    • It's refreshing to see an Apple product with user replaceable/upgradeable RAM.
  4. Mac mini Late 2012 Teardown: adım 4, 3 resimden 1. Mac mini Late 2012 Teardown: adım 4, 3 resimden 2. Mac mini Late 2012 Teardown: adım 4, 3 resimden 3.
    • We're fans of easily removable fans.
    • Easily accessible fans mean soot sprites better run for cover, because cleaning dirty fans is no problem.
    • Need to clean your fan? Directions can be found here.
  5. Mac mini Late 2012 Teardown: adım 5, 2 resimden 1. Mac mini Late 2012 Teardown: adım 5, 2 resimden 2.
    • We remove the fan cowling, eager to get at the Wi-Fi antenna plate.
    • We are really starting to suspect that Dr. Emmett Brown had something to do with this mini as the antenna board and grille look identical to the last two renditions.
  6. Mac mini Late 2012 Teardown: adım 6, 2 resimden 1. Mac mini Late 2012 Teardown: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Mac mini Logic Board Removal Tool
    • Here we find the legendary Mac mini logic board removal tool in its natural habitat.
    • Note the ease of use as the tool swoops in to release the logic board of the mini.
  7. Mac mini Late 2012 Teardown: adım 7, 3 resimden 1. Mac mini Late 2012 Teardown: adım 7, 3 resimden 2. Mac mini Late 2012 Teardown: adım 7, 3 resimden 3.
    • The first component off the logic board assembly is the speaker assembly.
    • The speaker cable was arranged in a twisted pair, probably to reduce EMI that could distort the sweet, iconic tones of the Apple startup sound.
  8. Mac mini Late 2012 Teardown: adım 8, 3 resimden 1. Mac mini Late 2012 Teardown: adım 8, 3 resimden 2. Mac mini Late 2012 Teardown: adım 8, 3 resimden 3.
    • The Wi-Fi board, labeled BCM94331PCIEBT3B, stands no chance against our spudger as we make it truly wireless.
    • Removing the EMI shields allows us to peek at the ICs on the communications board:
    • Broadcom BCM4331 802.11 a/b/g/n Wi-Fi chip
    • Broadcom BCM20702 Bluetooth 4.0 transmitter
    • SiGe 5503A 2304A Dual Band 802.11a/b/g/n Wireless LAN Front End
    • SiGe 2598L
    • P2303A TUB2P
    • 7871 1228 C6050
  9. Mac mini Late 2012 Teardown: adım 9, 2 resimden 1. Mac mini Late 2012 Teardown: adım 9, 2 resimden 2.
    • The heat sink is next to go.
    • Apple has really keyed in on their boomerang-style heat sink abilities—and for that, we applaud them. We know boomerangs can be tough to master.
    • Similar, again! We have not tried installing old 2011 mini parts in the 2012 mini, but we are certainly not ruling out the possibility!
  10. Mac mini Late 2012 Teardown: adım 10, 3 resimden 1. Mac mini Late 2012 Teardown: adım 10, 3 resimden 2. Mac mini Late 2012 Teardown: adım 10, 3 resimden 3.
    • A series of screws and tightly wrapped antenna cables secure the rear I/O panel shield to the logic board.
    • A few twists of our precision aluminum driver with a T6 Torx bit and some cable de-routing is all it takes to remove the shield.
  11. Mac mini Late 2012 Teardown: adım 11, 1 resimden 1.
    • Some mini players on the top of the not-so-mini logic board:
    • Cirrus Logic 4206B Audio Controller
    • SMSC USB2512B USB Hub Controller
    • Broadcom BCM57765 gigabit ethernet and memory card controller
    • Intel L232TB45 Thunderbolt Port Controller
    • LSI L-FW643E-2
    • DELTA 8904C-F Filter
  12. Mac mini Late 2012 Teardown: adım 12, 1 resimden 1.
    • The rear side of the logic board:
    • Intel HM77 (SLJ8C) platform controller hub
    • Intel V227C254 2.5 GHz dual-core i5
    • SMSC 1428-7 system management bus temperature sensor
    • Parade PS8401A HDMI/DVI level shifter
    • LM4FS1AH
  13. Mac mini Late 2012 Teardown: adım 13, 2 resimden 1. Mac mini Late 2012 Teardown: adım 13, 2 resimden 2.
    • Tucked away neatly near the rear of the mini is the hard drive.
    • Our model came with a 500 GB Hitachi hard drive.
    • The mini is one of the Macs launched with the Fusion Drive.
    • Apple's Fusion Drive is not to be confused with the Impulse Fusion Drive of Star Trek.
  14. Mac mini Late 2012 Teardown: adım 14, 3 resimden 1. Mac mini Late 2012 Teardown: adım 14, 3 resimden 2. Mac mini Late 2012 Teardown: adım 14, 3 resimden 3.
    • Next up, we displace the power of the mini.
    • It is beginning to feel repetitive to say how repetitive Apple is in the design of the mini; nonetheless, the power supply appears identical to last year's model.
    • In this case, we have to say that repetition is a good thing, as the mini continues to be one of the most repairable devices that Apple produces.
    • Just like last year, the power supply provides 85 watts to the Mac mini—that's the same kind of electric juice as the AC adapter for a 15" or 17" MacBook Pro.
  15. Mac mini Late 2012 Teardown: adım 15, 3 resimden 1. Mac mini Late 2012 Teardown: adım 15, 3 resimden 2. Mac mini Late 2012 Teardown: adım 15, 3 resimden 3.
    • We were especially curious to see if this new Mac mini is still compatible with our dual hard drive upgrade kit, so we got to testing it!
    • Following along with our own guide for the 2011 model was a snap, and everything fit perfectly.
    • After a quick reassembly, we booted this guy up for the first time—with 50% extra storage. Success!
  16. Mac mini Late 2012 Teardown: adım 16, 2 resimden 1. Mac mini Late 2012 Teardown: adım 16, 2 resimden 2.
    • Mac mini Mid 2012 Repairability: 8 out of 10 (10 is easiest to repair).
    • No proprietary screws are found within the device.
    • You can easily upgrade your RAM and hard drive, as well as add a secondary drive.
    • There's no glue anywhere inside that needs to be removed while disassembling the mini.
    • The CPU is soldered to the logic board and not user-upgradeable.
    • While not difficult to do, you still have to remove almost all the internals in order to replace the power supply.
17Kılavuz Yorumları
Hello,
I see that Mac mini Late 2012 have a Hitachi HTS545050A7E362 HDD
What kind of SATA connection have that Hitachi HDD?
And what kind of SATA connection have Mac mini Late 2012? SATA II or SATA III?
Regards
nickeditor - Yanıt
Can you add in an SSD with your dual drive kit to see if Fusion turns on somehow?
Below - Yanıt
Can you confirm that you can add a second hard drive if you choose the fusion drive option? I believe Apple have used that extra space in the mac mini to pack in the 128GB SSD for the fusion drive.
Roy - Yanıt
when reinstalling the heatsink did you notice the heatsink does not 100% connect to the platform hub?
even when screwed down tight and new thermal paste applied there is still a paper thin gap between heatsink and platform controller hub
can anyone else confirm this???
thanks
kevin
beanieboy182@hotmail.com
kevin - Yanıt
I noticed this too
Victor -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 103
Son 30 gün: 582
Her zaman: 410,763
