Ana içeriğe geç
Mac mini Late 2014 AirPort Card Replacement
Neye ihtiyacın var
  1. Mac mini Late 2014 AirPort Card Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 AirPort Card Replacement: adım 2, 3 resimden 1. Mac mini Late 2014 AirPort Card Replacement: adım 2, 3 resimden 2. Mac mini Late 2014 AirPort Card Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 AirPort Card Replacement: adım 3, 2 resimden 1. Mac mini Late 2014 AirPort Card Replacement: adım 3, 2 resimden 2.
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 AirPort Card Replacement, Antenna Plate: adım 4, 1 resimden 1.
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 AirPort Card Replacement: adım 5, 2 resimden 1. Mac mini Late 2014 AirPort Card Replacement: adım 5, 2 resimden 2.
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 AirPort Card Replacement: adım 6, 1 resimden 1.
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 AirPort Card Replacement: adım 7, 2 resimden 1. Mac mini Late 2014 AirPort Card Replacement: adım 7, 2 resimden 2.
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 AirPort Card Replacement: adım 8, 2 resimden 1. Mac mini Late 2014 AirPort Card Replacement: adım 8, 2 resimden 2.
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 AirPort Card Replacement: adım 9, 1 resimden 1.
    • Remove the antenna plate from the Mac mini.
  10. Mac mini Late 2014 AirPort Card Replacement, AirPort Card: adım 10, 1 resimden 1.
  11. Mac mini Late 2014 AirPort Card Replacement: adım 11, 3 resimden 1. Mac mini Late 2014 AirPort Card Replacement: adım 11, 3 resimden 2. Mac mini Late 2014 AirPort Card Replacement: adım 11, 3 resimden 3.
    • Use the point of a spudger to lift the antenna connectors up off their sockets.
  12. Mac mini Late 2014 AirPort Card Replacement: adım 12, 1 resimden 1.
    • Remove the 2.7 mm T5 screw securing the AirPort card.
  13. Mac mini Late 2014 AirPort Card Replacement: adım 13, 3 resimden 1. Mac mini Late 2014 AirPort Card Replacement: adım 13, 3 resimden 2. Mac mini Late 2014 AirPort Card Replacement: adım 13, 3 resimden 3.
    • Lift the free end of the AirPort card enough to grasp it by the edges.
  14. Mac mini Late 2014 AirPort Card Replacement: adım 14, 2 resimden 1. Mac mini Late 2014 AirPort Card Replacement: adım 14, 2 resimden 2.
    • Pull the AirPort card straight out of its socket on the logic board and remove it from the Mac mini.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
465.783 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
4 Yorum
Thanks. Took all of 20 minutes start to finish to upgrade my broken NIC.
Erik Westlund - Yanıt
Hmm, look like an M.2 interface, could an M.2 SSD be installed instead?
The Bionic Cyclist - Yanıt
Can confirm that the airport card for the 2015 Macbook Pro fits and functions perfectly as a replacement if you can’t find the mac mini one.
Sam Goddard - Yanıt
If something wrong with my bluetooth, is it also replace this logic board ?
Gordon Lee - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 35
Son 30 gün: 141
Her zaman: 19,851
