Giriş
Use this guide to replace the SSD stick in an SSD only, or Fusion Drive model of the Mac mini Late 2014.
Neye ihtiyacın var
The bottom cover is clipped onto three screw posts.
Pry near, but not right on the screw posts.
Remove the following TR6 screws from the antenna plate:
Three 4.1 mm screws
Three 1.9 mm screws
110 farklı kişi bu kılavuzu tamamladı.
32Kılavuz Yorumları
If I have a Mac Mini without SSD, only with normal Hard Drive (NO Fusion). Can I install a new one SSD like on this tutorial?. Thanks!
Please see my comment later in the thread.
Si, yo lo hice y la diferencia es abismal. Necesitaras un adaptador y por supuesto el SSD. Yes, I did it and the difference is abysmal. You will need an adapter and of course the SSD.
I have the same question as Juan
