Ana içeriğe geç
Mac mini Late 2014 SSD Replacement
Neye ihtiyacın var
  1. Mac mini Late 2014 SSD Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 SSD Replacement: adım 2, 3 resimden 1. Mac mini Late 2014 SSD Replacement: adım 2, 3 resimden 2. Mac mini Late 2014 SSD Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 SSD Replacement: adım 3, 2 resimden 1. Mac mini Late 2014 SSD Replacement: adım 3, 2 resimden 2.
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 SSD Replacement, Antenna Plate: adım 4, 1 resimden 1.
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 SSD Replacement: adım 5, 2 resimden 1. Mac mini Late 2014 SSD Replacement: adım 5, 2 resimden 2.
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 SSD Replacement: adım 6, 1 resimden 1.
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 SSD Replacement: adım 7, 2 resimden 1. Mac mini Late 2014 SSD Replacement: adım 7, 2 resimden 2.
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 SSD Replacement: adım 8, 2 resimden 1. Mac mini Late 2014 SSD Replacement: adım 8, 2 resimden 2.
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 SSD Replacement: adım 9, 1 resimden 1.
    • Remove the antenna plate from the Mac mini.
  10. Mac mini Late 2014 SSD Replacement, SSD: adım 10, 1 resimden 1.
    • Remove the 5 mm T5 screw securing the SSD.
  11. Mac mini Late 2014 SSD Replacement: adım 11, 3 resimden 1. Mac mini Late 2014 SSD Replacement: adım 11, 3 resimden 2. Mac mini Late 2014 SSD Replacement: adım 11, 3 resimden 3.
    • Lift the free end of the SSD up slightly and pull it out of its socket.
  12. Mac mini Late 2014 SSD Replacement: adım 12, 3 resimden 1. Mac mini Late 2014 SSD Replacement: adım 12, 3 resimden 2. Mac mini Late 2014 SSD Replacement: adım 12, 3 resimden 3.
    • Carefully lift the SSD out of the case without scratching or touching the gold contacts.
Sonuç
108 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
474.990 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.735 adet Kılavuz yazıldı
32Kılavuz Yorumları
If I have a Mac Mini without SSD, only with normal Hard Drive (NO Fusion). Can I install a new one SSD like on this tutorial?. Thanks!
Juan Miguel Ramirez - Yanıt
Please see my comment later in the thread.
Thomas Hall -
Si, yo lo hice y la diferencia es abismal. Necesitaras un adaptador y por supuesto el SSD. Yes, I did it and the difference is abysmal. You will need an adapter and of course the SSD.
Manuel Jesús Flores Jiménez -
Yes, but you need to add a cable to connect it. If you buy the SSD from OWC, they sell a kit which includes the cable and tools (for an extra $20-40, depending on what size/model SSD you get).
shamino -
I have the same question as Juan
Cronan McNamara - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 28
Son 7 gün: 168
Son 30 gün: 1,286
Her zaman: 193,085
