Giriş
Use this guide to easily remove or replace the plastic bottom cover on your Mac mini.
Neye ihtiyacın var
Lift and remove the bottom cover.
Align it carefully so that the words "Mac mini" can be read when the ports are facing you.
Then, press down on the cover to snap its three hidden clips into place.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Check eBay for unibody Mac mini bottom covers. You can also 3D print one if you want to.
I got as far as this step to do one thing, blow out all the dust. It was far enough and a lot of dust came out. I used a XPower A-2S to blow out the dust.
nirv - Yanıt
