Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Tilt the mini enough to allow the bottom cover to fall away from the outer case.
Remove the bottom cover and set it aside.
Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
Lift the fan out of the mini for enough clearance to access its connector.
Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
Remove the fan.
Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
Lift the cowling from the end nearest the antenna plate.
Rotate the cowling away from the outer case and remove it from the mini.
Remove the following screws securing the antenna plate to the mini:
Two 6.6 mm T8 or T9 Torx screws
Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either will work)
Slightly lift the antenna plate from the end closest to the RAM.
Carefully pull the antenna plate straight away from the circular rim of the outer case.
Use the tip of a spudger to carefully pry the antenna connector up off the AirPort/Bluetooth board.
Remove the following three screws:
One 5.0 mm T8 Torx or 2.0 mm Hex screw (either will work)
One 16.2 mm T6 Torx screw
One 26 mm T6 Torx standoff
Carefully pull the wires for both hard drive thermal sensors upward to lift their connectors up and out of the sockets on the logic board.
Use the flat end of a spudger to pry both the hard drive and optical drive connectors up out of their sockets on the logic board.
To disconnect the optical drive thermal sensor, pinch its cables between your thumb and a spudger and pry the spudger upward to lift the connector up and out of its socket on the logic board.
Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
Bu adımda kullanılan alet:Mac mini Logic Board Removal Tool$4.99-
Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac mini Logic Board Removal tool.
Simultaneously push the two plastic clips on the far left and right sides of the I/O board toward the middle of the I/O board and pull the I/O board away from the outer case.
Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
Use a pair of tweezers to disconnect the power cable from the logic board.
Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
Use the tip of a spudger to carefully pry the PRAM battery up and out of its holder on the logic board.
23 farklı kişi bu kılavuzu tamamladı.
3 Yorum
I believe Apple COULD have buried the battery a little deeper....yes?
All of my elderly Mini 2,1 still are running correctly with their original PRAM batteries.
I still have three Mini 2,1 models in use as DVR’s using EyeTV running OS X10.75 because the last version of EyeTV to still use the free TitanTV guide doesn’t work with 10.8 or higher and the TV Guide program guide was a subscription service until it was discontinued. Further development in North America was probably dropped due to legal issues since the last version allowed you to record and edit HDTV programs in full HD 1080 resolution and burn them to DVD in Blu-ray format if the original file was less than 90 minutes with a dual layer DVD while longer files could be burned to recordable Blu-ray. The DVD with Blu-ray content plays on every Blu-ray player I have tried them on.
These instructions were perfect and I am sure glad I ordered the Mac mini logic board remover tool along with the angled forceps they also sell in the store. Replacing the PRAM took care of all the weird gremlins I was experiencing trying to boot from a 1TB SATA 3 Samsung SSD. Now its like a new computer!
