Ana içeriğe geç
Mac mini Mid 2011 Bottom Cover Replacement
Neye ihtiyacın var
  1. Mac mini Mid 2011 Bottom Cover Replacement, Bottom Cover: adım 1, 2 resimden 1. Mac mini Mid 2011 Bottom Cover Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
  2. Mac mini Mid 2011 Bottom Cover Replacement: adım 2, 1 resimden 1.
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
Bitiş Çizgisi
17 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
The base plate on my MM has no thumb dimples, no “lock dots”, and it won’t budge. I’ve tried everything short of prying it off—light touch, firm touch, thumbs, palm, nothing has worked. Any suggestions?
Jonathan Royce - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 95
Her zaman: 25,289
