Ana içeriğe geç
Mac mini Model A1283 Hard Drive Replacement
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. Mac mini Model A1283 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Remove the two Phillips screws connecting the underside of the hard drive to the internal frame.
  2. Mac mini Model A1283 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Remove the two Phillips screws securing the side of the hard drive to the internal frame.
  3. Mac mini Model A1283 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Use the flat end of a spudger to pry the hard drive thermal sensor board off the adhesive securing it to the side of the hard drive.
  4. Mac mini Model A1283 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Remove the strip of tape holding the thermal sensor cable to the hard drive and remove the thermal sensor from the hard drive.
    • You'll want to transfer this thermal sensor to the same position on your new hard drive.
  5. Mac mini Model A1283 Hard Drive Replacement: adım 5, 2 resimden 1. Mac mini Model A1283 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Slide the hard drive toward the speaker to disconnect it from the interconnect board.
    • Lift the hard drive from the edge opposite the fan and remove it from the internal frame.
Sonuç
1Rehber Yorum
For all those poor people who have wrecked their Minis by following the bad advice on this page, I fixed mine by replacing this part:
http://www.powerbookmedic.com/Mac-Mini-I... (Apple part no 922-8807).
I did manage to solder a connector back onto the visible contacts on my original board, but it didn't work; the replacement worked fine.
If your cable is damaged too, you'll need to replace that too, but note that there are several different ones, and SKU17434 (Apple part 922-7319) is NOT compatible with the above board. I don't know the exact model of cable - having received the wrong one I managed to repair my original one.
Marcus Bointon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 59
Her zaman: 2,255
