Ana içeriğe geç
MacBook Air 11" Early 2014 Fan Replacement
Neye ihtiyacın var
  1. MacBook Air 11" Early 2014 Fan Replacement, Lower Case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Early 2014 Fan Replacement: adım 2, 1 resimden 1.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Early 2014 Fan Replacement, Battery Connector: adım 3, 2 resimden 1. MacBook Air 11" Early 2014 Fan Replacement, Battery Connector: adım 3, 2 resimden 2.
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Early 2014 Fan Replacement, I/O Board Cable: adım 4, 2 resimden 1. MacBook Air 11" Early 2014 Fan Replacement, I/O Board Cable: adım 4, 2 resimden 2.
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Early 2014 Fan Replacement: adım 5, 1 resimden 1.
    • Lift and remove the I/O board cable.
  6. MacBook Air 11" Early 2014 Fan Replacement, Fan: adım 6, 2 resimden 1. MacBook Air 11" Early 2014 Fan Replacement, Fan: adım 6, 2 resimden 2.
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  7. MacBook Air 11" Early 2014 Fan Replacement: adım 7, 2 resimden 1. MacBook Air 11" Early 2014 Fan Replacement: adım 7, 2 resimden 2.
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
  8. MacBook Air 11" Early 2014 Fan Replacement: adım 8, 2 resimden 1. MacBook Air 11" Early 2014 Fan Replacement: adım 8, 2 resimden 2.
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Early 2014 Fan Replacement: adım 9, 1 resimden 1.
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  10. MacBook Air 11" Early 2014 Fan Replacement: adım 10, 3 resimden 1. MacBook Air 11" Early 2014 Fan Replacement: adım 10, 3 resimden 2. MacBook Air 11" Early 2014 Fan Replacement: adım 10, 3 resimden 3.
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
471.504 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.430 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 22
Her zaman: 6,989
