Giriş
Use this guide to replace your MacBook Air's AirPort/Bluetooth card.
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
11 farklı kişi bu kılavuzu tamamladı.
