Ana içeriğe geç
MacBook Air 11" Late 2010 Fan Replacement
Neye ihtiyacın var
  1. MacBook Air 11" Late 2010 Fan Replacement, Lower Case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Late 2010 Fan Replacement: adım 2, 1 resimden 1.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Late 2010 Fan Replacement, Battery: adım 3, 2 resimden 1. MacBook Air 11" Late 2010 Fan Replacement, Battery: adım 3, 2 resimden 2.
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Late 2010 Fan Replacement, Solid-State Drive: adım 4, 1 resimden 1.
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 11" Late 2010 Fan Replacement: adım 5, 2 resimden 1. MacBook Air 11" Late 2010 Fan Replacement: adım 5, 2 resimden 2.
    • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  6. MacBook Air 11" Late 2010 Fan Replacement, I/O Board Cable: adım 6, 1 resimden 1.
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  7. MacBook Air 11" Late 2010 Fan Replacement: adım 7, 1 resimden 1.
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
  8. MacBook Air 11" Late 2010 Fan Replacement, Fan: adım 8, 1 resimden 1.
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Late 2010 Fan Replacement: adım 9, 1 resimden 1.
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 3.6 mm T5 Torx screw
  10. MacBook Air 11" Late 2010 Fan Replacement: adım 10, 1 resimden 1.
    • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
thanks a million—clear and accessible.And we did it!
gigi marks - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 12,680
