Ana içeriğe geç
MacBook Air 11" Late 2010 I/O Board Replacement
Neye ihtiyacın var
  1. MacBook Air 11" Late 2010 I/O Board Replacement, Lower Case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Satın Al
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
    I recommend that one of the tools you obtain is a jeweler's loupe that mounts on your glasses. It makes things easier.
    blairweaver - Yanıt
    This is not correct. You need the pentalobe tool at this point.
    Duane Hellums - Yanıt
  2. MacBook Air 11" Late 2010 I/O Board Replacement: adım 2, 1 resimden 1.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Late 2010 I/O Board Replacement, Battery: adım 3, 2 resimden 1. MacBook Air 11" Late 2010 I/O Board Replacement, Battery: adım 3, 2 resimden 2.
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Late 2010 I/O Board Replacement, Solid-State Drive: adım 4, 1 resimden 1.
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
    What happens if the 2.9mm t5 screw got stripped?
    Charles - Yanıt
    So when i change my ssd in mac do i have to reinstall Mac OS
    sai prahalad Alluri - Yanıt
    Correct, the SSD does not come with OS preinstalled. To install the OS you can completely clone your existing hard drive or you will need to create a bootable flash drive and format your SSD and create a partition in order to be able to install the OS.
    Ethan Lockwood -
    So my wife spilled a Martini on her MacAir and it no longer works and is not repairable, all her music and pictures are stored on the drive, I would like to transfer these files to another drive. What is needed to read the drive once removed?
    prastonis - Yanıt
  5. MacBook Air 11" Late 2010 I/O Board Replacement: adım 5, 2 resimden 1. MacBook Air 11" Late 2010 I/O Board Replacement: adım 5, 2 resimden 2.
    • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
    I performed all the steps above and fitted a Transcend JetDrive 500 which was very easy however when I re-assembled and turned on all I get is a question mark in the middle of the screen, can you explain if I did anything wrong?
    Ian Ashton - Yanıt
  6. MacBook Air 11" Late 2010 I/O Board Replacement, I/O Board Cable: adım 6, 1 resimden 1.
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  7. MacBook Air 11" Late 2010 I/O Board Replacement: adım 7, 1 resimden 1.
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
  8. MacBook Air 11" Late 2010 I/O Board Replacement, Fan: adım 8, 1 resimden 1.
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Late 2010 I/O Board Replacement: adım 9, 1 resimden 1.
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 3.6 mm T5 Torx screw
  10. MacBook Air 11" Late 2010 I/O Board Replacement: adım 10, 1 resimden 1.
    • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
  11. MacBook Air 11" Late 2010 I/O Board Replacement, I/O Board: adım 11, 1 resimden 1.
    • Remove the following five screws securing the battery to the upper case:
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  12. MacBook Air 11" Late 2010 I/O Board Replacement: adım 12, 1 resimden 1.
    • Do not touch or squeeze the six lithium polymer cells when handling the battery.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  13. MacBook Air 11" Late 2010 I/O Board Replacement: adım 13, 1 resimden 1.
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  14. MacBook Air 11" Late 2010 I/O Board Replacement: adım 14, 2 resimden 1. MacBook Air 11" Late 2010 I/O Board Replacement: adım 14, 2 resimden 2.
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the microphone ribbon cable straight out of its socket.
  15. MacBook Air 11" Late 2010 I/O Board Replacement: adım 15, 1 resimden 1.
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
  16. MacBook Air 11" Late 2010 I/O Board Replacement: adım 16, 1 resimden 1.
    • Pull the camera cable parallel to the face of the I/O board toward the rear edge of the Air to disconnect it from its socket.
    • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
  17. MacBook Air 11" Late 2010 I/O Board Replacement: adım 17, 1 resimden 1.
    • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
  18. MacBook Air 11" Late 2010 I/O Board Replacement: adım 18, 1 resimden 1.
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  19. MacBook Air 11" Late 2010 I/O Board Replacement: adım 19, 1 resimden 1.
    • Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Question. Im looking a replacing the I/O board on my MacBook air and am wondering if it matters whether I get the board for the 13” or the 11”? Are the two boards different? It seems that the 11” I/O board is cheaper so I just trying to figure out if it matters which one I get?
Tristan cusi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 14,567
