Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
MacBook Air 11" Late 2010 Logic Board Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. MacBook Air 11" Late 2010 Logic Board Replacement, Logic Board: adım 1, 1 resimden 1.
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  2. MacBook Air 11" Late 2010 Logic Board Replacement: adım 2, 2 resimden 1. MacBook Air 11" Late 2010 Logic Board Replacement: adım 2, 2 resimden 2.
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  3. MacBook Air 11" Late 2010 Logic Board Replacement: adım 3, 1 resimden 1.
    • Use the tip of a spudger to de-route the right speaker cable from the slot cut into the logic board.
  4. MacBook Air 11" Late 2010 Logic Board Replacement: adım 4, 1 resimden 1.
    • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
    • Pry up from beneath the cables.
  5. MacBook Air 11" Late 2010 Logic Board Replacement: adım 5, 3 resimden 1. MacBook Air 11" Late 2010 Logic Board Replacement: adım 5, 3 resimden 2. MacBook Air 11" Late 2010 Logic Board Replacement: adım 5, 3 resimden 3.
    • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
    • While holding the lock away from the socket, use the tip of a spudger and your fingers to gently remove the display data cable from its socket.
    • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
  6. MacBook Air 11" Late 2010 Logic Board Replacement: adım 6, 1 resimden 1.
    • Remove the small rubber gasket from the corner of the upper case near the display data cable.
  7. MacBook Air 11" Late 2010 Logic Board Replacement: adım 7, 2 resimden 1. MacBook Air 11" Late 2010 Logic Board Replacement: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
  8. MacBook Air 11" Late 2010 Logic Board Replacement: adım 8, 1 resimden 1.
    • Gently de-route the antenna cables from the slot cut into the logic board.
  9. MacBook Air 11" Late 2010 Logic Board Replacement: adım 9, 1 resimden 1.
    • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
  10. MacBook Air 11" Late 2010 Logic Board Replacement: adım 10, 1 resimden 1.
    • Gently lift the logic board assembly out of the upper case, minding the fragile heat sink and any cables that may get caught.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 341
